DesignSeries.pngEditing walls
Once a wall has been created, there are multiple ways to edit it:
Edit parameters from the Object Info palette.
Reshape walls using the Selection tool, the Reshape tool and the Delete Wall Peaks command.
Remove wall breaks.
Join walls and wall components, and move connected walls.
Edit curtain wall grids.
Wall properties
Reshaping walls
Removing wall breaks
Moving connected walls
Joining walls
Joining wall components
Editing curtain wall grids
